Machine Vision
Circles detection in grayscale
I'd like to detect circles in a 8bit image using the grayscale information (instead of brutally applying a threshold) in order to get sub-pixel accuracy.
Does Labview do that?
Did anybody write a program that does it?
I'm using labview 5.0.1 and Imaq vision.
thanks
(4,052 Views)
The good news is that it is relatively easy to do. The bad news is that it uses a new tool in IMAQ Vision 6.
There is a tool that will locate the edges of a circle and determine the size and location of the circle. It is called a circular rake. It basically finds edges along radial lines around the circle, then determines the circle parameters.
Bruce
Bruce Ammons
Ammons Engineering
(4,052 Views)
