Machine Vision
Can't install NIVision OpenCV Utilities (System) in VIPM, error code 8
HELLO,
I try to install  OpenCV Utilities in Labview 2014.( And I've already installed VDM and VAS.)
VIPM says I need to install  NIVision OpenCV Utilities (System) and  NIVision OpenCV Utilities . And the NIVision OpenCV Utilities (System) got errors when installing.Error code is 8.
Now when I open an opencv VI, it can't find the nivisosamples.dll.
How can I solve the problem ?
(5,259 Views)
I have the same problem with the same error report.
Does anyone have a solution or at least an idea?
Thanks and regards.
(5,066 Views)
Accepted by topic author ggsyx
Try this:
Launch VIPM with "Run As Administrator" Privileges:
  1. Right mouse click on VIPM shortcut and select "Run As Administrator" option
  2. If the option is not listed, try SHIFT+RightMouseClick
in my case it solved the problem...
(5,041 Views)
DHDR thanks, this solved my problem as well.
(4,738 Views)
