Machine Vision
Can someone help me make a VI for the attached Serial Camera?
OOOOOPs. So here it is again.......with AA 0D still nothing
Message 11 of 16
(1,667 Views)
What serial data is the complex labview VI Sending out. I put an O scope on the values and found the characters producing the wrong binary output how can I get A = 1010?
image1 is AA
image2 is AA 0D
you can see the two AA's in the first one then a termination character.
As well as with the AA 0D. Nomatter what configuration I put it in the termination character stays the same.
Anyways I was just curious!
Message 12 of 16
(1,645 Views)
Dear electric5,
So from the data sheet, it looks like  "A single command consists of 6 continuous single byte RS-232 transmissions. The following is an example of SYNC (AA0D00000000h) command (p. 3 of the data sheet you attached).
If the device is expecting 6 byte commands,and you are sending AA 0D (2 bytes), I think your device will interpret the input that you show in your setup picture as commands structured like this: (AA0DAA0DAA0D). What happens if you try sending the sync command (AA0D00000000h) over and over?
Best Regards,
~Nate
Message 13 of 16
(1,629 Views)
I have tried that too and it also does not work. The serial port is not outputing the correct form of data to talk to the camera. I am currently trying to figure out how to get the serial data to be output in hex rather than ascii. Let me know if you have any suggestions.
Message 14 of 16
(1,620 Views)
Hi electric,
                 Let the output be in ascii.Use "string to byte array" function.Now u have an output array  containing the 307200(640x480) bits.Use a reshape array function to convert this into an image keeping the aspect ratio in mind.If you are getting ascii values then u r work is almost done.Lemme know If you are still stuck
Message 15 of 16
(1,609 Views)
So we have gotten the acknowledge from the camera now we just need to send some more commands to get it to send the image data. Hopefully all goes well thanks for your help everyone!
Message 16 of 16
(1,601 Views)
