02-16-2011 02:59 PM
Should think about AVI?
JPEG?
02-16-2011 09:26 PM
Hi sachsm,
Regarding this question, I think we can talk from some aspects:
02-16-2011 10:00 PM - edited 02-16-2011 10:02 PM
Ok, I guess I was fishing to see if NI was planning on TDMS support for video streams.
So then, the question is what is most efficient:
IMAQ->AVI->Disk
IMAQ->JPEG->Disk
IMAQ->Some other compression format->Disk
IMAQ->Array->TDMS
Any prospects of taking advantage of GPU based compression?
02-17-2011 06:04 PM
The answer to this question very much depends on your computer. Your bottlenecks will be compression and writing to the hard drive. A fast CPU will allow for faster compression, while a fast hard drive will allow you to write to disk faster. If you have a solid state RAID drive, I would suggest saving uncompressed files to disk. I think the best option is to give different compression schemes a try on your computer.
