Machine Vision
Can NI1405 works with Panasonic WV-CL120?
Hi, I have a Panasonic WV-CL120 with WV-PS11A Cameras drive unit in our lab.
I hope to use it for direct image capture in PC. If you have use this camera with NI1405
card, please kindly let me know how it works. It will be helpful for me to make purchase decision.
Thank you!
Richard
(3,696 Views)
Richard--
     The 1405 is an analog framegrabber card and is compatible with any of the analog standards (NTSC, PAL, RS-170, or CCIR)  Please, refer to the link below
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14209
      I did a quick search on google to see what type of video signals the WV-CL120 uses. However, I wasn't able to find anything. Seems to be an old camera. The best thing to do is look in the manuals for that camera to see what type of camera it is and what type of signal it uses.  Then if it is one of the four listed above it should work with no problem.  After you check compatibility for the hardware then all you would need to get is a development environment to program (like LabVIEW or Visual Basic) and that should do it.
John H
(3,676 Views)
