02-21-2016 11:53 PM
Hi All,
I am planning to use 3 GigE cameras for my application. Also I have decided to use a desktop running NI RT OS. Does this frame grabber support RT? As per the specifications , http://sine.ni.com/nips/cds/view/p/lang/en/nid/211211 , the supported operating system is Windows,
However, in the overview section of the same webpage, it is mentioned that " 8233 is optimized for machine vision needs on both PC and real-time systems".
Can I connect NI PCIe-8233 to my RT desktop and capture images?
Regards
Aveo
Solved! Go to Solution.
02-23-2016 12:21 AM
Hi Aveo,
This card is supported on a Real-Time platform.
-Suraj
AE, NI India
03-09-2016 04:47 AM
Hi Suraj,
Thanks for your previous reply.
I found a spare frame grabber, NI PCIe 8237R , lying around my desk. I am currently planning to use this to capture images from 2 GigE cameras using a RT desktop. Before I dive into installing RT into the desktop machine I wanted to confirm once whether
1) 8237R can be used to capture images through a RT desktop?
Regards
Aveo
03-09-2016 08:02 AM
03-09-2016 11:20 PM
Thanks for the info!
