11-27-2007 05:15 PM
11-29-2007 08:29 PM
11-29-2007 09:28 PM
Thanks for the response.
I generally don't like copying dll's around like that, it's easy to get things crossed up or miss a dependency, though I know it would "work" but mis-report the version.
I believe that there are several more NI DLL's that can be involved, depending upon what's being used, though these may not be the RTE strictly speaking.
We are trying to work our way out from under the faulty FPGA design that's preventing us from using CVI 8.1 and up.
Menchar
11-30-2007 05:19 PM
11-30-2007 05:26 PM
Somebody else at NI has said that PCIe-1427 needs the IMAQ 3.8 version, it's not supported on the earlier versions that distributed correspondingly earlier versions of the RTE. And 3.8 distributes the 8.1 RTE.
BUT they also said you could remove the 8.1 rte and it would not remove the IMAQ SW (but it does remove CVI !) and then re-install just the 8.0 rte. I'd have to re-install CVI 8.0 then too.
Thanks for your help.
Menchar
12-03-2007 06:34 PM
