Machine Vision
Cameralink triggering
Hi bestbeir,
I am in the process of looking into this further as well as talking to R&D about this issue.  I will post back when I have any new information.  Thanks!
Kristen H.
Message 21 of 48
(2,990 Views)
Hi Kristen
Thanks for looking into my problem. Have you found anything yet?
Bestbier
Message 22 of 48
(2,938 Views)
Hi Bestbier,
We are still looking into it.  I do have one quick question for you:   Do you have Measurement Studio installed?  You didn't mention it before, so I assume not but I thought I would double check.  I am going to try to reproduce your issue on a fresh Windows image.
Kristen H.
Message 23 of 48
(2,920 Views)
Hi Kristen
I don't own Measurement Studio. I only have the Vision Development Module.
Do I need to get Measurement Studio?  If so which version?
I would think that for controlling a function on a vision acquisition board that is included in IMAQ would be possible without extra libraries.
Bestbier
Message 24 of 48
(2,906 Views)
Hi bestbier!
I am not sure if you will need Measurement Studio yet. Do you have SP2 for Windows XP?  I just want to make sure my system is the same as yours!  Thanks!
Kristen H.
Message 25 of 48
(2,885 Views)
Hi Kristen
My system is as follows:
Win XP SP2
IMAQ 4.1
Vision Acquisition 8.6
Vision Development Module 8.6
MS Visual Basic 2005
Bestbier
Message 26 of 48
(2,887 Views)
Hi bestbier,
I recreated your system using a virtual machine.  Unfortunately, I was unable to recreate the issue.  The "Add" button worked just fine.  Did you run the reinstall of the IMAQ driver from a disk or downloaded from ni.com?  At the moment, the only thing I can think might be the issue is a corrupt driver.  Could you try downloading and installing the driver from ni.com (http://joule.ni.com/nidu/cds/view/p/id/1099/lang/en) ?
Kristen H.
Message 27 of 48
(2,860 Views)
Hi, Kristen,
Can you please explain (just for me) - how you are able to communicate with PCI Device (IMAQ Camera Link  framegrabber in our case) from Virtual Machine?!
Or in another words, which Virtual Machine are you using for such test? From VMware its impossible as far as I know.
Looking for your feedback,
Andrey.
Message 28 of 48
(2,858 Views)
Hi Kristen
Just want to check some stuff. Have you setup the 1427 in MAX? Is it the "Add" button in the "Pulses" block that works? My "Add" button in the "Signals" windows works and the one in the "Pulses" blockid greyed out when I have the card installed, but does work when I don't have the card installed.
I have been using my 8.6 CD.
I am currently installing this system and will try this on a new PC tomorrow or Wednesday.
Bestbier
Message 29 of 48
(2,852 Views)
Andrey-
I was actually not communicating with a PCI device.  I was testing the software combination. Sorry about the confusion.  As far as I know, you are correct about not being able to communicate with PCI devices from a virtual machine.
bestbier-
I did not realize that this issue presented only when the board was installed.  Thank you for clarifying and double checking on that.  I am told that this issue is still under discussion in R&D.  I will post when I hear something!
Kristen H.
Message 30 of 48
(2,831 Views)
