10-08-2019 12:49 PM
Hi All,
I will have a laser pattern on a frosted acrylic sheet (6 mm thick). I will be measuring this laser pattern through this acrylic sheet with a camera and machine vision application. I need to calibrate this camera. I am going to use a dot grid on the acrylic sheet to calibrate the camera. However, I am having trouble finding a resource to print this simple dot grid on the acrylic sheet (black dots for high contrast vs the white translucent frosted acrylic sheet). I have found companies that print on acrylic, but all are for portraits, etc., none for engineering applications, and thus their tolerances are very poor, and as you know I need this dot grid to be near-exact.
Question: Have you printed on acrylic before for camera calibration? How did you do it?
I am trying to avoid printing on paper and then gluing it to the bottom of the acrylic if possible. Having the dot grid printed directly on the acrylic is a much more elegant solution that I would like to achieve.
Thanks!
10-08-2019 08:15 PM
Hello
I have calibrated the camera using the dot grid before. I have used a thin metal sheet and machined holes on it ( it is accurate) and then placed another black power-coated metal sheet behind the sheet.Now in a 2D perceptive, we can just see a sheet with black holes on it. I am not sure whether this will apply for your application, let me know your thoughts on it.
Hope it helps !
-Rahul
HIT KUDOS TO CONVEY THANKS
11-06-2019 09:00 AM
I haven't done printing on to acrylic before, but I have a few possible suggestions:
