Machine Vision
Camera Basler GigE and NI AI
I want to use a camera GigE Basler scA640-70gc and Vision Builder for AI in an application where to process above 3 images/seg., with this frequency is left time for the somewhat complex algorithms of processing?
best regards,
Mauricio.
(3,416 Views)
You can alway run your vision acquisition parallel to the analysis, so you should have pretty much the entire time for analysis.  Maybe subtract a couple of ms for acquisition just for safety.  If you are acquiring at 3 frames/second, that gives you about 330 msec for analysis of each image.
Bruce
Bruce Ammons
Ammons Engineering
(3,371 Views)
