03-08-2007 02:36 PM
03-09-2007 02:34 PM
To address your question, whether you correct/calibrate an image before you pattern match or vice versa will depend on your application and the end result you are trying to reach. The calibration process will take more time to run than a typical pattern match. Therefore, are you interested in calibrating just the images that are matched? This will take less time then calibrating all of the images and then doing a pattern match. If your pattern match process is rigorous enough to be able to find the suitable images, then I would suggest keeping with the first option you discussed. If you do need to calibrate all of your images, then the second method would suffice. It may also help your image processing in regards to matching score. I also see that you mentioned color planes. Are you acquiring three separate images and combining them to get the complete image? Again, the order in which you process your image will ultimately depend on the end result that you want. Please let us know if you would like further clarification or assistance regarding this issue, if so please provide additional details regarding the specifications of your application.
Vu D
Applications Engineer
03-09-2007 03:03 PM
03-12-2007 06:55 PM
Hello 2verb,
If accuracy is very important in this application, then I would say that calibration before you perform a pattern match would be essential. As I mentioned earlier, this process does take more time; therefore, you will need to weigh the value of accuracy with the time efficiency of the system. Also, if color is not necessarily as crucial, you also have the option of taking in the images as grayscale which will help reduce the processing of your application. I hope this helps.Regards,
Vu
03-12-2007 08:29 PM
03-13-2007 03:32 PM
Hi 2verb,
As I mentioned in my previous post, if your pattern match is robust enough to be conducted before or after calibration then you should be fine either way. You may be able to perform the image processing you need without image correction. Correcting an image will help verify that the image looks spatially correct, but is not always needed since the calibrated information is already included. Also, the correction process is a very time intensive operation since you will be redrawing the image. As mentioned in the Vision Concepts manual, if you are performing a particle analysis, for example, you can compute the calibrated measurements directly from an image that contains the calibration information but has not been corrected. There is more information regarding when and how to use correction / calibration in the Vision manual which can be found by going to Start >> Programs >> National Instruments >> Vision >> Documentation >> Search the NI Vision Bookshelf >> Concepts and Techniques >> NI Vision Concepts Manual page 55. If you still have questions after looking through this resource, please let us know.
Vu
