11-15-2004 10:08 PM
11-16-2004 12:27 PM
06-17-2005 10:32 AM
06-23-2005 10:06 AM
05-25-2006 06:31 AM - edited 05-25-2006 06:31 AM
Message Edited by Steve Penney on 05-25-2006 06:33 AM
Message Edited by Steve Penney on 05-25-2006 06:35 AM
06-05-2006 05:53 PM
10-12-2006 11:50 AM
10-12-2006 02:28 PM
Hi Anna,
In my experience, getting an external Firewire hard disk drive to work with a CVS boils down to two basic factors:
1.) The drive's Firewire interface must be OHCI compliant. This is very difficult to discern from the drive packaging and/or datasheets of the online retailers. I was forced to put a lot of time in to determine which worked well. To my recollection a Seagate drive works alright as does one from a company called ADS Tech (discontinued as far as I can tell).
2.) The drive must be formatted with the FAT32 file format. An NTFS drive will not be detected by the CVS.
I hope this helps. I did not have any problems with power cycling or seqeunced power-up that some of the other posts indicated. Make sure all of your CVS software is up-to-date.
10-12-2006 04:42 PM
10-15-2006 04:45 AM
Hi Anna,
The OHCI compliance refers to the firewire card that you have installed in your PC. I'm using an NI PXI chassis with the NI firewire card so I didn't have to worry about that part. If you are using a PCI firewire card in a PC then I'd suggest using a reputable firewire card manufacturer like Belkin which will include a statement on OHCI complience in the specs (see http://www.cwol.com/firewire/belkin-firewire-pci-card.htm).
For the hard drive, it looks like NI have tested a handful of chipsets that are used for the firewire interface to the hard drive. Most of these are Oxford chips and it looks like all the Oxford chipa they tested worked with the CVS, so to be on the safe side I'd go for an external hard drive that used an Oxford chipset. I've used a Maxtor OneTouch external firewire hard drive successfully with the CVS as these are based on the Oxford chips (the Maxtor OneTouch II uses an Oxford 912 chip and the OneTouch II uses the 924 chipset ... see these links:
http://www.maxtor.com/_files/maxtor/en_us/documentation/data_sheets/onetouch_ii_fw800_datasheet.pdf
I did have problems detecting the Maxtor drives in certain power-up conditions and these have still not been resolved (see previous post), but as long as you have the CVS powered up and the Maxtor hard drive is powered up and then then plug in the firewire cable for the Maxtor to the CVS, it should detect it (and as long as the drive is formatted to FAT32).
I hope this helps ...
Cheers,
Steven
