01-25-2018 03:09 AM - edited 01-25-2018 03:20 AM
I'm trying to mark(detect) 4 straight lines from a binary image and whether any of them are broken (not straith).
If there are any broken lines, i wish to mark(detect) these lines (edges) with a vertical line (which in this case(Test_Image) is located up in the right side corner).
I have created an application(VI) which seems to work well with the "raw" image, but when I extract the colorplane (blue) and try to detect the lines from the binary image (not the raw image), i can't seem to find anything. Maybe i'm using the wrong tools(VI's) or simply the wrong parameters(to much noise?).
Any suggestions?
(It works when I use: "First Edge Rake" detection, but then I can only detect one horizontal line)
02-08-2018 03:21 AM
Duplicate with thread here: https://forums.ni.com/t5/Machine-Vision/Broken-line-edge-detection-from-binary-image/m-p/3746061#M50...
Please continue to use that thread.
