04-04-2019 06:02 AM
I have camera Basler sprint spL4096-70kc and framegrabber PCIe 1430 and according to this web: http://sine.ni.com/apps/utf8/nipc.product?pid=8193&asid=1102 it should be working. I can see PCIe 1430 and camera in MAX, I can choose camera file created for Basler Sprint spL4096-70k but when I want to snap or grab I have a timeout error. I didn't change anything in the camera file.
I'm using base configuration for camera.
What do I need to change to make this camera work with framegrabber?
Ada
04-08-2019 08:42 AM
Hi Adriana_S,
Default icd file consists configuration only for PCIe-1433, 1435 and 1437 frame grabbers. With NI Camera File Generator you can easily create a new config file.
Second thought - Basler spL4096-70kc can operate in 8 taps mode (8-bit depth). At the same time, PCIe-1433 can work in 2 taps mode (max 12-bit depth, see link below). After adding new target frame grabber in NI Camera file Generator you will notice that throughput will be automatically limited to 2 taps.
http://www.ni.com/product-documentation/54610/en/
Cheers
