07-28-2009 08:52 AM
07-29-2009 01:28 PM
Hello pchitnis,
I've looked over Photron's website but it does not provide much information on the image acquisition or proprietary software that is used. I would suggest contacting Photron in this regard.
07-29-2009 01:41 PM
Hi andy,
Thanks for your continued efforts to help. It seems that Photron has C APIs that one might be able to convert into DLLs. I wonder if this is the only viable option?
07-30-2009 08:19 AM
Hi pchitnis,
If you use a camera-specific DLL to work with your camera, you can use the Call Library Function Node VI to call and interact with the DLL.
If your camera-specific DLL returns a numeric array to represent your image, you can use the IMAQ ArrayToImage VI to convert it into a form that LabVIEW can handle if you need to use it for other vision VIs. You would first need to use IMAQ Create to create a destination for that image to be placed, and wire its "New Image" out terminal as the "Image" input terminal to the IMAQ ArrayToImage VI.
07-31-2009 09:07 AM
