Machine Vision
Anyone used a Dalsa 5GigE camera with LabVIEW?
Dalsa assure me their new 5GigE cameras will work with cards like the PCIe-8239 but I won't get the highest possible speeds. (In which case, why buy the camera?) Does anyone have experience of using these faster cameras?
(3,348 Views)
Did you have any solution to your problem?
I would like to acquire images from a 5GigE JAI camera with IMAQdx but under NI IMAX I have a noisy image while it works fine with the "JAI Control Tool". For information, I don't use NI frame grabbers. Any INTEL PRO 1000 Ethernet board (hard to find now) and other Ethernet board even without INTEL chipset will work using more or less CPU... In this particular case, I tried several non-INTEL board and I can acquire at full speed with "JAI Control Tool" (without a noisy image) and also under NI MAX (but with a noisy image)...
(3,072 Views)
I appreciate the reply. No, I haven't pursued 5GigE yet, and your comment on noisy images concerns me.
When I get time (or can find someone to do the work for me 😉 ) I'll investigate further.
(3,063 Views)
For your information, updating the firmware of the board used in the computer and using jumbo packets with 9014bytes solved the issue...
But now i'm facing another issue : opening the camera takes around 25 seconds and loading a configuration file also takes 25 seconds, so if I open sequentially several cameras, my software can spend more than 4 minutes to open... ðŸ˜¥
(2,751 Views)
You're using the NI Vision Acquisition software?
(2,735 Views)
Yes
(2,731 Views)
