Machine Vision
Analysing stereo images with lower resolution than calibration images
I have calibrated my setup with images at higher resolution, but in my program I'd like to use smaller resolution stereo images to execute IMAQ Stereo Correspondence SG Block Matching. I use IMAQ Read Binocular Stereo File to upload the calibration file, but it is not working well if I change the resolution (if I run the program with the same resolution as I used for calibration it works fine). Is it possible to to work on different resolutions somehow?
Another question is whether I can run IMAQ Stereo Correspondence SG Block Matching algorithm with part of the images.
Patrycja
Message 1 of 1
(2,003 Views)
