09-14-2023 09:25 AM - edited 09-14-2023 09:28 AM
Dear community,
I have quite a weird problem. I have updated a lab PC from LV2014 to LV2020. Accordingly the IMAQdx package.
I have three Aliedvision MantaG_032B cameras (656x492 pixels, mode: mono12packed).
They are connected to the PC via Netgier Gigabit Switch GS108.
With IMAQdx 2014 driver I could not find any problems.
After the update:
1st Problem:
When StreamBytesPerSecond are set to maximum 1.15E+8, black streaks appear in the image and cameras are lost regularly. The problem can be solved by reducing the value. In theory, this should not be necessary, because cameras are triggered and takes a shot per second. I would like to understand why it worked with old IMAQdx and not with newer one.
What is even stranger: I tested this PC in my office with an Allied Vision Manta G-419B-NIR (2048x2048 pixels), a Basler scA1390-17gm (1390x1040 px) and a Basler scA640-17gm and found no problems by StreamytesPerSecond maximum! The switch in the office is Netgear GS308P.
Problem 2:
Increasing the StreamBytesPerSecond incrementally may cause a camera or the driver to send three ghost images in an infinite loop. IMAQdx Grab2.vi returns a new frame number and not a real image but allways the same three images from a buffer. This is highly weird and not funny in a laserlab: operators think that they see a real beam, because image changes!
My start grab routine looks like this:
And grab looks like this:
Did anyone have the same problem?
09-29-2023 07:29 AM
After a long unsuccessful search, I set up another PC fresh with Windows 10 pro and NI Academic Suite 2020 and the problems are gone.
05-19-2026 03:12 AM - edited 05-19-2026 03:14 AM
By accident, I found a reproducible setup and solution 🎉
Symptoms
Setup
Root Causes
Changed Settings
Parameter |
Before |
After |
NIC Receive Buffers |
256 |
2048 |
NIC Interrupt Moderation |
Enabled (Adaptive) |
Disabled |
StreamBytesPerSecond |
55,000,000 |
90,000,000 |
