03-01-2011 07:28 AM
First, I found no place where the algorithm used by IMAQ Learn Calibration Template is documented. Is it my impression, or something is kept under the carpet? The question has been asked before in the forum (this thread, this thread), but I'm not aware of an answer.
In particular, I'm concerned with what the "nonlinear" distortion is doing - while I would assume that it could attempt, for instance, some sort of least square fit to polynomial functions X(x,y), Y(x,y), from my experiments it rather seems that the algorithm is doing some tessellation of the image to be calibrated, then apply some piecewise affine transformation to each piece of the mosaic. The result may be acceptable for a dense calibration template like that shown in the examples, but it is odd for sparse points. In the attached FP image, I calibrate the lower image versus the upper, and then overlay to the latter straight gridlines in pixel coordinates, to the lower the (finely resolved) transformed gridlines in "world" coordinates. Note the sharp wiggles between morsel and morsel! Displaying the image adjusted with IMAQ Correct Calibrated Image also confirm that this is what is going on. (this in LV2010, at least)
Second, I think there are some limitations in the way the calibration VIs are supposed to be used. In my work, I met:
Any comment?
Enrico
03-03-2011 11:58 AM
Hi Enrico Segre,
Unfortunately we do not have documentation detailing the calibration process for our images. I can, however, point you to the Perspective and Nonlinear Distortion Calibration help document. You may also get insight from What are the Requrements for an NI Vision Calibration Grid?
Lynn
03-03-2011 12:40 PM
Already read and providing no information in this respect.
Enrico
03-04-2011 11:23 AM
Hi Enrico,
I will continue to look into your concerns as see if there is any information I can provide addressing them.
Lynn
03-06-2011 02:20 AM
Thanks, that would be helpful. In the meantime, for my application, I think I'd implement a low degree 2d polynomial fit for the coordinate transformation. That would be controllable and independent from any associated image buffer.
Enrico
03-11-2011 01:40 PM
Hi Enrico,
Unfortunately, all of the information I can give you, you have probably found in our NI Visions Concepts manual. Beyond that, our process is proprietary. I will however, submit your feedback to R&D so that they are aware of your concerns.
Lynn
03-15-2011 03:04 AM
Well, polynomial fit works much better, and it is way faster than IMAQ Learn. I didn't do extensive timings, which of course depend on whether the error table and calibration table are to be retained and on the number of fiducial points provided, as well as on the size of the original image (mine are BIG); but at first sight, it's a matter of some tens of ms (poly) vs 10 sec (Learn) on my test case.
I implemented the poly fit with just a few lines of mathscript code, which need as input just the registration point data and not the associated image. Limitations are perhaps that I don't compute the error estimate (but could, it is standard regression analysis), I don't carry along the morphing table (for Image adjust), and that the poly transformation is not easily invertible for degree>1 (but the inverse fit can easily computed).
Attached below is an image from my test VI.
Enrico
03-15-2011 08:30 AM
Dear Enrico Segre,
Seems like I have a problem that have some similaritys.
I want to make Images of +/- 1m², token by 3 camera's, who take each 4 pictures(of 5Mpix each).
All the pictures need to be calibrated seperatly, and then combined together.
I only have +/- 1sec to do this, together with some extra's like thresholding...
Can you help me with the polynomial fit?
=> How does it works?
=> Can you send me some code?
=> And how fast is it in compare to the "correct calibrated image.vi"
Kind Regards,
Frederik Deneire
03-15-2011 08:38 AM
Great stuff, Enrico
Would you consider sharing your mathscript code as an open source e.g. on github.com ?
btw. your ants seems to be dead - they haven't moved for more than 2 months..
Jakub
03-15-2011 11:12 AM
I would be tempted to say "it's proprietary..."
Anyway, the whole mathscript code, including comments, is:
% input data x(i),y(i), z(i), k=1...n % p=order of desired polynomial in x % q=order of desired polynomial in y % works for x,y,z either column or row vectors % output: matrix c (q*p), such that zi=yi.^(0:size(c,1)-1)*c*xi.^(0:size(c,2)-1)' % flattening idea found on Tian-Bo Deng, proceedings ICICS 97, p.1288, % but the idea is simple and essentially also in Bevington X=max(abs(x)); Y=max(abs(y)); % rescaling to condition properly f=zeros((p+1)*(q+1),length(z)); for i=1:length(z) f(:,i)=kron((x(i)/X).^(0:p),(y(i)/Y).^(0:q)); end alpha=f*f'; beta=f*z(:); c=reshape(beta'/alpha./kron(X.^(0:p),Y.^(0:q)),q+1,p+1);
for the fit part (to be done twice, once for X(x,y) and once for Y(x,y)), and
for the mapping part (also to be done twice).
Attached also the complete VI together with ancillaries - I'm in a generous mood today... Please just keep in mind that it is a proof-of-concept evaluator, not a complete application. For the sake of evaluation, I was just happy comparing two images of a scene taken by different cameras, treating the coordinates of one image as "true world", and computing the deformation of the second image.
Btw, if you play with the degrees of the fitting polynomials, you get obviously nonsense if you try to determine more coefficients than the points you have. The system is underdetermined, etc.
no, two weeks - it's the american date format....
Enrico
Enrico
