Machine Vision
Acquire images from the stereo camera Bumblebee (PointGrey Research Inc.) under LabVIEW using IMAQ for IEEE1394
Did somebody control the stereo camera Bumblebee (PointGrey  Research Inc.) under LabVIEW using IMAQ for IEEE1394?
How can i acquire images (stereo pair) with LabVIEW?
Message 1 of 11
(8,972 Views)
Hello wlan,
the Point Grey  Bumblebee Camera is a IEEE1394 Camera and works under the IIDC - Standard with the NI-IMAQ for IEEE1394 Driver http://digital.ni.com/softlib.nsf/websearch/161B95F09A55347F862571EF00549358?opendocument&node=13207....
For aquire pictures from both cameras, please test the following LV - Programm.
Message Edited by Uwe Symolka on 09-22-2006 01:56 AM
Message 2 of 11
(8,961 Views)
Hello Uwe,
thanks a lot for your answer. After i changed the camera driver to the NI-IMAQ-IEEE1394 driver, i can get images in MAX. The images are from the right lense, the camera name is cam0.
But wenn i add a cam1 into a VI, that can not be recognized.
The Bumblebee camera has 1 firewire interface and 2 lenses.
Can you tell me what should i do so that i can get stereo pairs?
Thanks!
WLAN
Message Edited by wlan on 09-22-2006 05:39 AM
Message 3 of 11
(8,935 Views)
Hello wlan,
so the camera is very new. Is it poosible for you, to send us the camera for testing this apllication ??
my address is
Uwe Symolka | Vision Consultant | National Instruments | ni.com
Konrad-Celtis-Str. 79 | 81369 München | Tel.: +49 89 7413130 | Fax: +49 89 7146035
thanks
Message 4 of 11
(8,926 Views)
I am using NI Vision Acquisition Software Version 8.2.3 for windows and trying to connect bumblebee stereo camera, but It is not detected by the NI-IMAQ.
Any help would be appreciated.
Ashish
Message 5 of 11
(8,606 Views)
According to the Pt. Grey Datasheet the Bumblebee is compliant with the IIDC 1394-based Digital Camera Specification v1.31. Both NI-IMAQdx 3.0.x and Legacy NI-IMAQ for IEEE 1394 Cameras 2.0.x support IIDC cameras. I recommend using NI-IMAQdx for new application development. The driver is available for download from:
http://digital.ni.com/softlib.nsf/websearch/5153F722B0F33FFA862572AE004E2FE4
I have not tested the Bumblebee. I am not certain how to get images from both sensors. I will try to get my the bumblebee and see if we can data streams from both sensors.
Hope this helps,
JohannS
Message Edited by JohannS on 06-26-2007 10:40 AM
Message 6 of 11
(8,594 Views)
how to get images from both sensors is the key problem. I didnot make it. Please try it and tell us your method if you can do it! Thanks a lot!
Message 7 of 11
(8,577 Views)
Well, in my case I am not able to see either of the stereo camera and I do have the latest NI-IMAQ drivers. I have also tried on compact vision system (Real-Time Hardware), which didn't work either. I know my camera works because I am able to grab images using  Digiclops.
Any  suggestions?
Thanks.
Message 8 of 11
(8,553 Views)
In MAX, select NI-Driver as you camera driver!
Message 9 of 11
(8,548 Views)
and you can get images, but only from one sensor (i think it was the left one...)
Message 10 of 11
(8,545 Views)
