11-06-2017 09:28 PM
Hi everyone,
I used this example "calibrate stereo vision system.vi" and there are some problems.
As the following pic, firstly, it didn't show correctly in right/left calibration grids. Then I refer to this: "https://forums.ni.com/t5/LabVIEW/Stereo-vision-calibration-failed/td-p/3041599". It can display well, however it does not go to next step, e.g. show corresponding points dialog, when coverage is completed.
Does anyone could help me? Thanks.
11-06-2017 10:15 PM
I trace the trigger signal to show "corresponding points dialog", it return false (not trigger) from calibration manager (in "add grid images" function). Then, tracing into it, "computer camera model" return false. It is difficult for me to solve at current status.
Any suggestions? Thank you.
