Machine Vision
About 12 μm detector of IRay Technology-Advantages & disadvantages
In March 2018, at the IWA2018 exhibition in Nuremberg, Germany, I saw the IRay’s 12 μm 640, 384 detector. After a year of contact with IRay, I successfully tried the latest 12 μm outdoor thermal monocular in the previous period. That’s really a super product ,  as far as I know there are some advantages with a 12μm detector for thermal monocular comparing to 17μm .
I did some tests with monocular with 12 μm detector plus a 25mm lens and the other one17μm detector plus a 35mm lens which is amazing,the observe distance is the same! And when they both use the 25mm lens, the observe distance of 17um detector is over 30% more than the 17 μm detector .
The material used for the 12 μm detector is VOx which has significant advantages than a-Si. NETD is less than 40mK, 14-bit digital output is supported.High sensitivity and easy to use,it keeps the primary competitive advantages of IRay products. Currently IRay 12 micron 1280×1024, 640×512, 384×288, and 256×192 full range detectors have been in mass production. The following is a specific description of the 12-micron detectors.
Resolution 1280×1024,12 μm
Features
  1. Super large FPA ,XGA high resolution detector;
  2. Frame rate up to 60Hz  ;
  3. Typical power consumption is less than 350mW;
  4. NETD < 40mK (@f/1.0, 30Hz, 300K);
5.14-bit digital output.
  1. Supporting detector Evaluation Kit (can be customized)
Resolution 640×512/384×288
Features
  1. Available with ceramic or wafer level (WLP) packages;
  2. 14-bit digital output;
  3. Frame rate up to 60Hz
  4. Under typical working conditions, the power consumption of 640 and 384 array products is less than 150mW and 100mW respectively;
  5. NETD≤40mK (@f/1.0, 50Hz, 300K);
  6. Support for TEC-less andshutter-less applications.
  7. Supporting detector Evaluation Kit (can be customized)
Resolution 256×192
Features
  1. 14-bit digital output;
  2. Wafer level packaging (WLP);
  3. Provide a standard I2C interface;
  4. Support 5V/1.8V standard voltage and support MCU-based application solutions;
  5. Under typical operating conditions, the power consumption is less than 60mW.
  6. Supporting detector Evaluation Kit (can be customized)
So products with 12μm detectors have advantages in size,weight,power consumption etc.
I heard that IRay will bring more 12 μm products to Laser-world of Photonics 2019 exhibition in München,Germany. If you have more information about them, please leave a message.
(3,403 Views)
This forum is very few people, but they are all big-level
(3,368 Views)
no people?
(3,347 Views)
12μm infrared detector
(3,331 Views)
Hello Frankliu
So i see that you have programmed this camera in labview? Is there a driver package avaialble, or is it possibly directly supported in NI-IMAQdx?
(2,537 Views)
