11-02-2007 04:52 PM
Solved! Go to Solution.
11-03-2007 12:52 AM
11-13-2007 09:28 PM
03-17-2008 03:57 PM
03-18-2008 08:09 AM
03-18-2008 11:08 AM
Many thanks Oliver, that works really nicely giving us extended shutter times to 4s.
Paul
10-18-2010 03:02 PM
I'm using the Stingray 145C and am not able to change the shutter using this VI - I get an error when I run it. I'm able to change the timebase by writing values to the appropriate register (offset = F1000208, value varied from 2147581952 to 2147581959) but haven't been able to control the Shutter the same way. Do you happen to know the offset and values I should use for these, or have any suggestions to get your VI to run with my CCD?
Any help would be appreciated. Thanks.
03-20-2011 01:39 PM
I need some helps to use the Guppy F-046B/C camera.
I'm trying to get many frames with variable shutter knowing precisely to what shutter i'm recording.
I'm able only to use matlab with image acquisition toolbox 3, but it is not enough, because i can't utilize the camera's properties!! What any other software can i use?
I have also the AVT Guppy Tecnical Manual V7.1.0!
Raimondo
03-21-2011 06:32 PM
I don't know if you have used it yet, but you can access properties using Measurement & Automation Explorer, NI's hardware configuration tool. However, these will only take affect if you utilize LabVIEW with Vision Acquisition Software. If you would like to demo these products feel free to visit the following website:
Demo Vision Acquisition Software
Lynn
