12-02-2014 03:59 PM
The part number of Vision Run Time has changed ??: First 778044-00 and then 778044-03 and then 778044-35
The 778044-35 is only currently available.
I need the 778044-03 because is the 2011 version.
will "778044-35" work with 2011 Vision Run-Time?
Thanks !!
12-02-2014 05:16 PM
Generally all the licenses are backwards compatible---a 2014 license will activate licensed features in a 2011-built application. I would suggest checking with your local NI salesperson to be sure regarding the differences between those part numbers.
12-03-2014 08:10 AM
Thanks !
