I'm using a NI1744 Smartcam to connect to a cRIO-9012, this works through a tcp connection. I did set this up to communicate without a PC.
It's fully working if I use the first port of the Smartcam, if I try to use the 2nd port nothing happens.
I did set it up at MAX, I did choose the same IP as the first port, also tried different IP's but nothing seems to help.
Even if I simply put the ethernet cable in the 2nd port and connect it to the PC it doesn't show up in MAX, if I put the PC in the first port and cRIO in 2nd nothing happens.
Is this 2nd port totally useless and just for show or what am I doing wrong?
The only thing I wanna do with the PC is to show the Image of the smartcam on a laptop screen and add some simple functionality to the system. Like a pause button, previous/next buttons.
On both ports I use a static IP setup
