MMU LabVIEW Proficiency Group
Waveform Chart vs. Waveform Graph
May I know what is the difference between Waveform Chart and Waveform Graph?
I try to connect the waveform graph with a simple DBL input and it can't works, but it works in the waveform chart, so how should the connection looks like in waveform graph?
(21,293 Views)
A graph basically displays single or multiple existing data all at once with evenly distributed points.
Be it from an array or a log file data.
So, u may have an array of a recorded temperature data and u plot it at one time on the graph, similar to the X_Y cartesian graph.
Whereas, for chart, it display single or multiple data that is acquired and update at a constant rate.
For instance, measuring a temperature in real time and plotting in on the chart.
So referring to your question, you are wiring a double integer input into a graph. this could not work because the graph only accept input of 1d array,
such that the output will be a plot of an array of data on the graph.
Why it works for the chart?
It is because chart accepts a single data or an array of data, and it plot the current input as it executes.
Thus, you will need a predefined or an existing array of double value data in order to plot on a graph.
(12,256 Views)
Thanks for your reply.
So I have to use the chart to display a real time data at a constant rate.
Is that possible to show 2 signal (or plot) in 1 single waveform chart?
(12,256 Views)
Yes and it is possible to plot single or multiple signal in a single waveform chart.
(12,256 Views)
thx Kelvin, I get it done by using array to cluster.
now I have another question, how do we update a set of array inside a while loop? I try to link the array to the output of "build array" but it shows mismatch.
(12,256 Views)
Hi Jeffry, if you want to update the array inside the while loop as it executes, u may use a shift register or a variable depending on what value you are updating. Do you mean you are wiring an array constant to the input terminal of the build array vi?
(12,256 Views)
