MMU LabVIEW Proficiency Group
Reply
8-Graphs & Charts Updated (20th April 2012).pdf
(6,022 Views)
Re: 8-Graphs & Charts Updated (20th April 2012).pdf
I had try and successfully use multiplot for XY graph. But the problem with the XY plot, after i close the VI and reopen again, each plot (other than plot 0)  need to be assign the graph properties like line style, line width, and so fourth. How i can fix this problem by giving default value for each plots and don't need to reassign all the properties.. The data source come from csv file which also need to browse everytime, which then i export through array subset to select respective column and row and plotting them into XY graph.
Thanks in advance for any comment and suggestion.
(2,528 Views)
Highlighted
after i play around, i found short cut menu from the graph, Data Operations > Make Current Value Defaults . i'll keep my eye to see how good this shortcut menu help me
(2,528 Views)
Reply
