This probably points to a compiler issue. Usually when installing Visual C++ your path variable points to the Visual C bin directory which has nmake.exe in it.
Can you invoke nmake from the command line? If not, your path isn't set up right.
To set it up, please run the vcvars32.bat (in the vc7/bin directory)
Dirk
