Hi
I am using MATRIXx 7.0
I found problem with SystemBuild interactive simulation that it completes very fast if resume button pressed.
So if you have put any control buttons, the simulation will over before you could reach there except you have entered very large time line of about [0:.01:1000] or so.
But this takes very much time.
So is there any solution?
One thing i found is even after giving large time line vector after it runs ,the mouse movement becomes very slow and it does not work properly.
Other thing i noticed that if you press Ctrl+t that time step it works fine. Things going slowly and you can easily access controls but you somehow have to manage pressing down Ctrl+t and move mouse!
So is there any way to do this effectively??
Regards
Ishant Dave
