I have not been able to find something for the tpl. So far I am able to get that info from Xmath with the function you specified and also with the version command. In System Build you could use the same through a Mathscript block. I will try to find a solution for tpl.
"os_uname_s" TPL token return "PC" on windows platform.
found this in "c_sim.tpl":
@IFF STRCMP(os_uname_s, "PC")@@
@gen_pc_makefile()@@
@ELSE@@
@gen_unix_makefile()@@
@ENDIFF@@
This is not described in the TPL user's guide. I also found "ucb_filenames_ls" and "nucb_filenames_i" tokens that are not listed in TPL user's guide. are there other TPL undocumented features?
