Lookout
one control update another (Lookout 4.0.1)
I am trying to support a customer with very old code in Lookout 4.0.1. What I need to do is get one Pot control to update the value in another. They have this in place already and I have tried to copy how this is done but when I do this by adding a new control (Pot Object) and setting the value parameter (right click, edit connections.. in Connection Browser) to the other control it does not update. I suspect I have missed a parameter somewhere but I don't know what it is!!
If anyone could guide me I would be very grateful
Kevin
(3,384 Views)
In your process, if there are two pots which are pot1 and pot2, and you want to use pot 2 to control pot1, you can right click pot1 and choose edit connections, then confugure it as the following pictures, the function will be realized. You can have a try again.
(3,353 Views)
Thanks that was very helpful, I had the connection the wrong way round i.e. I thought I had to write  the value in rather than read it. All sorted, thanks.
I do have another related question though, how do I set Pot2 value from a push button. I want to set it to zero when the button is off and to say 20 when on. I can see I can use the same connection principle but how do I apply the coding logic I need.
Thanks again
Kevin
(3,349 Views)
If the pot is pot1 and the push button is pb1, you can configure the pot edit connection as the following picture.
(3,332 Views)
Thanks!
Kevin
(3,325 Views)
