I am trying to use a custom graphic from the image navigator in an expression in the Lookout 6.0.2 program, but when I use this graphic and convert it to a WMF, Lookout returns an error "Graphics Directory Does Not Exit!". The graphic I am modifying is the T-Intersection pipe that is located in the NI Pipes folder that is accessed with the image navigator. I have rotated this particular pipe 270 degrees and shaded it with a turquoise fill color. I have used the straight Pipe and Elbow pipes from this folder and altered them then converted them to WMF with no problem. Any assistance with this problem or a work around would be appreciated. Thanks. Werner
