02-13-2003 08:16 AM
02-13-2003 09:05 AM
Hi Steve,
Yes. What you do is open the .LKS file in a text editor. This is the "source code" for your process. Here, you can copy-n-paste, add/modify, and then open it in Lookout thus compiling it back into a process file (.l4p).
However, a better solution for your case seems to be to use the Aggregate Object. This is basically defining your own object which can include other Lookout objects. So, if you define an Aggregate object called "MyStation," all you do next time you add a new station is to create and use this MyStation object, like any other object.
See Online Help on this Aggregate Object for details.
Best Regards,
Khalid
02-14-2003 11:18 AM
