The "nonexistent, access denied" message would imply (I am guessing here) that the Process is unreachable.
For you to find out if you're using the OPCFieldPoint or the native FieldPoint, you would have to go into Edit mode, and then in the Object Explorer from the Object menu. Here, you should see your FP Objects. Right-click them and go into properties to find out what kind of an object they are.
You can also find this info' from the LKS file. Look for the "new" keyword in there.
Connection browser, again under the Object menu in Edit mode, lets you see the relationships between various objects and processes. Looks like you're having problems because not all of your processes are running. El
iminate this possibility by making sure all your processes are running. We shall then see if you still get the red Xs.
Khalid
