I have a situation where there is a flow meter that shows the water flow per gallons, in realtime,
The water flows only when a certain pump starts. The flow may start at 600 gpm while starting to fill a tank and then go down to 200 gpm when the tank starts to get full.
Could, and how, would i use an accumulator to track the total number of gallons that flows through the pipe?
When the pump starts i do have a register in the PLC that i can monitor to tell if pump is running. Would i need this or just use the accumulator to sum the actual values coming from the flow meter?
thanks
