Brett,
I have been looking over your post and have a few suggestions. The first one is in regard to the syntax in the INI file that you posted.
From the INI file that you posted:
[SelectedProcesses]
P0=\\www.telemetry.trl.oz.au\FishFarm_server
Count=1
MinPriority=1
MaxPriority=10
AreaName=FFM
[SelectedProcesses]
P0=\\www.myserverurl.com\FishFarm_server
Count=1I noticed that you listed the "[SelectedProcesses]" token twice in your INI file. If you refer to the
KnowledgeBase on this topic, you will find that you should only list the token once, and each successive server should have its own P value. In addition, MinPriority, MaxPriority, and AreaName are not valid arguments for the token. I would imagine that your INI file should look more like this:
[SelectedProcesses]
P1=\\www.myserverurl.com\FishFarm_server
Count=2
If you still have trouble after modifying the INI file, I would suggest trying the following:
-Accessing the server over a LAN instead of the Internet (using the machine name instead of the .com address)
-Modifying the server address in the INI file to use the IP address instead of the .com address
-Accessing the server using a run-time client (non-web client)
-Verifying that you have client licenses available by going to Help » About Lookout and checking the number of licenses that you have available
If you are unable to get the process working by modifying the INI file, then please post back with the results of the other testing. With that information, I believe that this forum will be better equipped to help you solve this problem.
Best of luck with your application.
Jed R.
