Lookout
VERTICAL TEXT
I would like to rotate a text entry 90 deg so that I may use it as a label on an X/Y graph. How can I do this?
(3,018 Views)
I think the only way around this is to use custom graphics, and import them into Lookout.
(3,018 Views)
Hi Carl,
There's no built-in "feature" to do this. However, you can get the vertical-text effect, by using individual (one character) text expressions lined up on top of each other.
If the label is coming from a TextEntry object, you can use the text function "mid" to extract the right character.
I am attaching an example process file demoing this.
Hope this helps.
Khalid
(3,018 Views)
