Sorry I don't have an absolute answer for you (yet). I could use some more info from you though. What are all of your settings in your AB-SLC500 driver? Can you connect to the plc with RSLinx using the same serial cable? Make sure that your settings in your Lookout driver are the same as the config of your RSLinx driver.
