"Robert Phillips" wrote:
>>With PLC logic, it is easy to turn on alarm with "MOV" statement to turn
on>bit.>>Is there any comparable way to turn on an alarm without having each
tag related>to the alarm mentioned in the "connection"?>>
If I understand you question correctly this will work. Create an alarm group
with each of the related tags part of that group. Then have the alarm go
high whenever any member of this group is in active state.
