11-04-2016 01:54 PM
Is there a way to create a 3 position switch? I am using Lookout 6.5 for this project
Solved! Go to Solution.
11-04-2016 07:26 PM
Here is an example of two different ways of creating an HOA switch using a Pot object and a Radiobutton object. There are other ways of doing this using other objects also, but this might help you get started. I could not upload the lks file, I had to change the extension to txt.
11-07-2016 08:41 AM
Thanks I will read thru this. Unfortunatly I am running Lookout 6.5 so could not install code directly.
Get a couple of syntax errors.
11-07-2016 11:58 PM
Hello, you can create a new process, save it and then open it on notepad, replace the original content with the text content pasted above, the original process is endited by version 5.1, so you are able to open it in Lookout 6.5.
11-14-2016 10:20 AM
Not sure why I could not get code working at first but finally got it working. by fixing the lines it was giving me errors on. Thanks
