11-13-2007 12:47 PM
11-14-2007 02:48 AM
11-14-2007 08:03 AM
Hello Ryan,
Ok, doing the reading by MAX worked. I checked the message that is being sent by the instrument, and it is correct when I select "no parity bit".
But in the field "return status", in the VISA Test Panel, it shows the same hexadecimal code for the framing error. So, if I use the VISA Read command, in Labview, it will keep on not working. What should I try now, so that I don´t have this framing error anymore?
Thank you once more for your answer.
Guilherme
11-14-2007 11:17 AM
