Yes you can do this, and the methods differ depending on what version of Lookout
you are using. There is a knowledge base article on the subject.
"Everardo Hernandez" wrote:
> Hello all.> I am new to Lookout, I have used other SCADA and HMI
software, so I>wondered about the possibility of reusing objects between
screens. I tried>to copy an object from a different process file and it says
it is not>possible. What if I want to use a standard control panel in my
applications,>such as an About dialog?> Thanks in advance.>>
