In which way do you add the hypertrend to report?
I connect hypertrend.graphic to report.display. When the report is created, there will be an html file and a bmp file. The bmp file is the hypertrend. So, in the html report, there are no more hypertrend objects, but only some pics. If the pic shrinks to a small one in report, you can check the bmp file if it is still of the right size.
And also you can check if the bmp is black. If it is, the hypertrend in report should be black.
Message Edited by Ryan.S on 09-21-2006 09:45 PM
Ryan Shi
