Hi, I have 2 LookOut processes (client & server) that work fine. The client is a web client which requires access to the alarms generated by the server so web users can see alarms that occur when they are not connected. The "NI AlarmEvent Browser" object seems perfect for this and in fact works ok when under development. However, with the inclusion of this object the client process no longer will export. The error message "Cannot export this ActiveX Control: Alarms\AlertBrowser1. Only those National Instruments ActiveX controlls installed with Lookout can be exported". The failed file to be exported is "5108.ocx" (which does not exist under the lookout install directories). There is the lookout5108.ocx object so perha
ps there is an incorrectly named pointer in the AlarmEvent Browser (if I make a copy of lookout5108.ocx named 5108.ocx then the same failure occurs but due to now lookout5108.ocx not being found). I am using Lookout 5.1 build 8.
Well this object came with lookout and functions fine in the development environment so it appears that something is missing....
