06-08-2009 09:43 AM
Solved! Go to Solution.
06-09-2009 01:53 AM
I don't know the meaning of your expression (value*35000)/65535, but if you want a value be counted by ten in an expression, you can use this formular
int(value/10)*10
06-09-2009 07:48 AM
thanks ryan....sorry the value was the reading from the scale in a vmemory location from the plc...35000 was my span....but what you gave me worked fine...now if i can figure out how to get that expression back into my plc i'll be set....randy
