10-08-2007 08:17 AM
10-08-2007 08:29 AM - edited 10-08-2007 08:29 AM
switched OPC client in Lookout from "Local Server" to "In-Process Server" and the the following error
OPC/OLE error (1) couldnt create an OPC server object (65) Class not registered (80040154)
maybe this helps
thx
wp
Message Edited by wespiece on 10-08-2007 08:30 AM
10-08-2007 10:10 PM
10-09-2007 08:06 AM
The file is posted as Secureplex OPC.zip on the FTP site. To anyone else who may want it, i can email it, it's only 2mb. The driver was written by Flexware Innovation 317-813-5400. I tried to contact them but they never returned my call. Maybe someone can look at the OPC server with serverexplorer and see what i am doing wrong. Serverexplorer sounds like a nice tool but is not included with Lookout. Thanks for the help. Let me know what you find. wp
10-09-2007 09:24 PM
10-10-2007 11:08 PM
i can now see the data items in the OPC client inside Lookout but i cannot get the field i/o to respond. I created an expression that points directly to one of the data input points and it does not change status. Input I0007 is a watchdog bit that goes from off to on about once a second to indicate communications is ok with the field i/o cpu. I no longer have the comm fail issue. i should be able to fire outputs in lookout and see the message in the opc server that i posted. any ideas would help.
thx
wp
10-27-2007 08:41 PM
10-28-2007 10:00 PM
11-06-2007 09:17 AM
wespiece
It does not sound like this was your original problem, what did you change just before getting the DLL error?
11-06-2007 09:24 AM
