08-06-2010 02:46 PM
I need help with a Lookout error I get when I change an Alias in Lookout. I make my change, then a while later I get an error that says:
Lookout Application Error
0x0061569e referenced at memory 0x00200066 the memory could not be read
Please select ok to close the application.
Has anyone seen this error before? What can cause it.
Also, if I just restart Lookout, the Trending no longer works until I reboot.
08-09-2010 03:24 AM
What's version of lookout?
Does it crash every time you edit the Alias?
08-09-2010 12:32 PM
Its an older version.
Yes, it crashes every time after a few minutes.
08-11-2010 04:14 AM - edited 08-11-2010 04:24 AM
Can you create a new one with expected configuration and different Alias name? And then edit the .lks file by notepad, find and replace all the old alias with the new alias. So the new Alias will work and you can delete the old one.
Before you edit the .lks file, backup it first.
The problem looks like a known issue. We did fix it but I'm not sure if we have fix for your version.
08-11-2010 11:02 AM
Thanks for the help.
Is it true that if you don't set up any special Graphics or write to any files, the minimum recovery in case of a failure would be
all of the .l4p, l4t, .lka and .lks files, also the Lookout.ini and the Database Folder. Of course after you re-install Lookout. Does that sound right?
08-16-2010 02:12 AM
Yes. All the process files, and ini file, and database folder.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
