06-07-2007 01:19 PM
06-07-2007 08:53 PM
It seems that Logos is not installed properly. Try to repair the Lookout.
Please also make sure to have windows administrator privilege.
06-08-2007 10:10 AM
06-10-2007 09:52 PM
07-10-2007 03:42 PM
Well we got the liscense installed and everything is working for the most part.
Have one more question, I have been able to get lookout client to work fine on a brand new machine with only lookout client installed.
However if i install the client on another machine attempt to run lookout I get the same error as before the only difference is there is another program installed
on it called Citiworks which also i SQL back end driven. Wondering if you knew if there was a know compatibility issue with lookout and this software or if something else is wrong.
Any infromation appreciated
David Woodcock
CIty of Saint George
Water Services
07-11-2007 09:01 PM
07-12-2007 09:41 AM
08-03-2007 12:13 PM
Well found out that it was citiworks. As long as the computer only has lookout installed it works fine but if you install cityworks it wont work.
Well at least we know now.
