08-26-2005 09:22 PM
08-27-2005 01:01 AM
08-28-2005 01:18 AM
Rob,
Both errors seem to have occured in GDI32.dll -- this is a Windows' dll responsible for display, graphics, printing, etc. So you may want to look closely at such operations around the time the problem occurs.
The Dr. Watson log should give us more info'. You do not have to attach the entire log -- open the file in Notepad, go to the end of the file and search for the word 'Fault' backwards. Once you find it, copy and paste that portion of the log, including a few lines above it.
-Khalid
08-29-2005 09:05 PM
Hi
I am fairly certain that the hard drives are ok. I have nothing in the logs for the raid controller indicating any problems. I have surface scanned them for any problems and none were found. I have also looked at the windows logs and found no drive related problems. The system has been running ok for about a week and a half now but I am a little leary of it. I had thought about a total reinstall of XP and lookout but that is very time consuming and I would have the system down for approx 6 hours. If I have to go this route I will but I would rather not due to the downtime. This system runs a city fresh water system and due to the heat we have been having recently they are having trouble keeping up with the demand. There is a backup system but it does not work very well in a high demand situation.
The log I have said it was from Dr. Watson in the windows error event I have attached it in a zip file. I could not find any fault text in it so maybe theis is not the log you were asking about. If there is another place Dr. Watson logs get saved please let me know and I will find the information you requested.
Thank you for any help you can give me.
Rob Miller
08-31-2005 12:53 AM
For some reason the text on the left in the log file is not what I usually see -- a dot seems to have been inserted after each character. I was thus able to locate the "F.A.U.L.T" in the log, but there isn't much info' to figure out which function in Lookout is causing this crash in the GDI32.dll, unfortunately.
Do you use lot of animations on your panels?
-Khalid
08-31-2005 01:20 AM
Hi
I do have quite a few animations in use. There are approx 9 on the main panel and 5 or so each on 3 other panels. Is this a problem?
Thanks again for your help
Rob
08-31-2005 09:15 AM
08-31-2005 04:56 PM
09-01-2005 08:58 AM
