Lookout
Lookout V6.0 Hypertrend Data Display
I'm trying to use a hypertrend object (hyper.cbx) for use on my lookout client process.  On the local client/server machine, the object works fine and I am able to graph data.  However, when I try to export and view this via the web client the object displays but no data is present.  Any ideas here?
When used locally, the link to the data is follows:
\\.\WSESServer\HANNG\PLC_HANNG.ANLG_LVL_DOSING
When used remotely, the link to the data is as follows (using a symbolic link with the computers IP address and server process name of \\<IP Address>\WSESServer):
..\[LNK_WSES_SERVER]\HANNG\PLC_HANNG.ANLG_LVL_DOSING
It should be noted that I am using other display objects in a similar manner and both scenarios work fine.
Any ideas?
Thanks for the help,
Andrew
(4,638 Views)
If firewall is enabled on either computer, follow this KB to configure it.
http://digital.ni.com/public.nsf/allkb/0D7B86F4B4D19A5E86256F9A006EECB1?OpenDocument
Ryan Shi
(4,632 Views)
Hi there,
The firewall is acutally not turned on.  Any other ideas?  Per my original post, all other objects seem to work OK and update as expected.
It should be noted that a red X does not appear in the hypertrend display, the data just doesn't show up.
-andrew
(4,624 Views)
Good info thanks.
Message 4 of 3
(893 Views)
